Change Park light out 96 Jeep Grand Cherokee
Syberfinder
11-12-2009, 12:21 PM
Can anyone help me figure out how to get to the front park light on 96 Jeep Grand Cherokee so I can change it out? :banghead:
Thanks,
Godzilla.vs.Jeep
11-22-2009, 12:32 PM
You will need a torx tool, as I recall there are two screws that are accessed from the front to remove that assembly.
Get a strong flashlight and look for those screws.
Not hard once you locate those two screw heads and have the proper size torx.
Syberfinder
11-25-2009, 12:36 AM
Okay this works. Use a screw driver to help spread the lights apart a little then find a very long torx tool and a light. There is also one under the hood that holds that light in too. When you put it all back it is very difficult to get the light bracket in the front going so a suggestion would be to screw the front screw in a ways before putting the light back in, use a wire cutter or a dremal tool to v out the hole at the bottom. When putting the light back in the hole sits in the proper spot and can be screwed in place later with little or no problems.
