Cherokee Stalling PO340sportsman 11-04-2009, 06:24 PM I have a 2000 Grand cherokee 4.7. It stalls while driving & after about 20 25 minutes it starts & runs. I have a code PO340 (camshaft position sensor)Where is the sensor located & how hard is it to replace.BUT I've been told that this is not the problem. Any suggestions would be helpful. Thanks hundahunta 11-06-2009, 11:27 PM on the passenger side of the cylinder head by the air box......10mm sportsman 11-08-2009, 08:46 PM on the passenger side of the cylinder head by the air box......10mm Thanks for the input. I changed the sensor & it ran good for about & hr. Than I drove it about a mile & it died. It ran & died 4 times within a 5 minute period. Now I can put in it neutral,start it & keep it running by feathering the gas. It runs rough & has a fuel smell coming out of the exhaust. I have another code P1296. (5 volts output to map sensor open) Do you know what this means? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
