99 Tahoe Will Crank but won't FIRE!dfederly 11-03-2009, 01:09 AM I have a 1999 Tahoe V8 5.7. I was getting an antifreeze/oil mix, so after two months of sitting, I took the engine down to the head gaskets, replaced with all new gaskets from the head up. Scraped and cleaned everything, new plugs, new wires. Got it back together, now it won't start, it'll turn over and sound like it wants to fire but won't. I have gone through the troubleshooting guide in my Haynes manual. But most of what they offer for ideas is pretty basic and beginner. I am hoping someone on here might have an idea that I haven't thought of. I would list the things that I have done, but I would much rather check everything again if you think that could be it. So go ahead, spitball away I'm all ears. Thanks. manicmechanix 11-03-2009, 02:36 AM Have you checked for spark and checked the fuel pressure? Also double check ign, PCM, ign, fuel inj. fuses. MT-2500 11-03-2009, 08:59 AM dfederly 11-03-2009, 12:10 PM Thanks for the replies, I have timed the distributor/cylinders, and valves. Fuel Injector spider was dirty but I cleaned it off when putting it back together, I am getting fuel to the cylinders, I do have spark at the plugs, and I have compression out of the plug hole for cylinder #1. (Finger over the hole, turn engine over) I am sure the answer is there and it will be simple, I just can't imagine what it would be. I don't have a guage to check for fuel pressure, but I opened the release and got a pretty good spray, is that something I should look into more?? Also, I have been wondering about the Ignition Coil, is there a way I can test it?? MT-2500 11-03-2009, 01:18 PM After felling compression. Did you roll engine to no 1 cyl TDC compression stroke and then set dist as in picture? Also confirm plug wires on right check firing order. On fuel pressure you can not tell by a squirt. You need to put a gauge on it and confirm proper fuel pressure 60/66 lbs. you need 63-64 lbs on engiune cranking to squirt injectors. Rent or borrow or by buy a fuel pressure gauge. Some parts places rent or loan them. ON coil coil testing check for good hot blue spark out of coil tower. Then check for good hot blue spark to all plugs. dfederly 11-03-2009, 01:39 PM I will run to the local auto parts store and pick up a fuel pressure gauge to check that. One thing that I notice while checking plug wires is that I am only getting a white spark, not a hot blue, I don't know how significant that is, or what it signifies. I would like to test the ignition coil, but the instructions I've found for testing it don't seem all that clear. . . *********** Checked the fuel pressure, running at 64 LBS. . . Recently I've also started wondering if it could be one of the hundreds of sensors on this engine. Let me know what you think. . . . MT-2500 11-03-2009, 04:55 PM Make sure dist is set right on no 1 compression stroke. And spark plugs wires wired to firing order. Most flat top caps are numbered to what cylinder they fire. Put the right wire on the right plug. Make sure you have proper fuel pressure. Than check for good spark to all plugs engine cranking. If still no start pull plugs and check for wet or dry on end and make sure you have good AC delco plugs in it. Coil can be tested for good spark out of coil. A spark jump tester workes best. Spark should jump over 1/4 and have a good blue spark with a good sounding snap. manicmechanix 11-03-2009, 06:10 PM *********** Checked the fuel pressure, running at 64 LBS. . . Recently I've also started wondering if it could be one of the hundreds of sensors on this engine. Let me know what you think. . . . Just a suggestion, it would be best to post an update with another post so all will notice. I think you should verify that the distributor is really pointing to 1 TDC like MT-2500 mentioned. This a very common reason for no start after tearing the heads down. Check with a test light if the injector is getting powr and being pulsed on the other wire. j cAT 11-03-2009, 07:07 PM since you have a weak spark check the ground connections on the engine/distributor area, coil connections, corroded lugs etc... dfederly 11-03-2009, 09:14 PM The whole time I have been trying to start, I never once had a problem with the starter, now today after getting it put back together, the starter decides to go, so before I do any more trouble shooting I will have to fix that. It could be a little bit. I will post back with end results, thanks all for the help. j cAT 11-04-2009, 08:53 AM The whole time I have been trying to start, I never once had a problem with the starter, now today after getting it put back together, the starter decides to go, so before I do any more trouble shooting I will have to fix that. It could be a little bit. I will post back with end results, thanks all for the help. in a situation like you are in you crank 10sec. then no crank 3 min.if you crank too long and do not allow time for starter to cool you will destroy starter... battery is also a problem. after a series of start attempts the charger goes on and until battery is fully charged start attempts can resume.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
