1968 302 oil passage plugs
bcownie
11-01-2009, 12:44 PM
I'm a first time engine rebuilder and have a question about oil passage plugs in the front of the motor. The reference material I'm using says there are 3 but does not show where they are located. It appears there are 2 left of the cam and 1 above and right of the cam behind the distrubitor shift. Is this correct? Also above the cam to the left there's a rough opening in the block about a 1/2 or so. Is this normal?
MrPbody
11-02-2009, 08:21 AM
bc,
Yes, this is all correct and "normal". If the engine rebuild is relatively stock, the pressed-in plugs are fine. Be sure to "swedge" them round the edges so they can't pop out. We use a sharp chisel to "fold" a small area of metal over the plug at 12-6 and 3-9 ("o'clock").
If this is a performance build, where it could "catch revs" quickly, it is recommended to tap the holes for "srew-in" pipe plugs. The holes are the correct size for 1/4"-NPT plugs. SOME blocks ARE "screw-in" plugs, but the vast majority we've seen are not.
The "rough" hole you refer to is a "return" hole (where the oil drains back from the valley).
Jim
bcownie
11-02-2009, 04:22 PM
Thank you!
