2000 Alero 3.4 litre - seized rotor
penguinforum
11-01-2009, 01:44 PM
I am changing my front wheel hub assembly (bearing finished)
I have been able to remove the axle nut and the 3 other bolts.
I am however having a hard time removing my rotor from the hub and the hub assembly.
Any suggestions (trying to salvage rotor)? I have alredy put Wd40 any where i can).
DECIDED TO REPLACE THE ROTOR. ROTOR IS NOW OFF. I AM ABLE TO MOVE THE AXLE ROD BACK BY TAPPING ON THE AXLE ROD (USING OLD NUT) BUT THE HUB WILL NOT COME OFF!!!
driver540
11-01-2009, 10:32 PM
Use a flat chisel and hammer to get in behind the hub assembly or if you have an air hammer with the chisel bit. They can be difficult, but thats the most effective way I have found.
