Terrible Front End Noise
risefedup
11-01-2009, 12:29 PM
You guys have been great help in the past and I hope someone can shed light on this problem. I have a terrible noise in the front end of my 2002 Impala LS. I have had front brakes, rotors turned, new bearings, new tie rod ends, 4 new tires, front and read alignment. This noise is a crunching sound and seems to be rhymic with the slowing of the car when I brake. I have had this to 4 mechanics and not one can find a problem. Someone mentioned to me to have the harmonic balancer checked. Any ideas?
Thanks
wafrederick
11-01-2009, 01:50 PM
Could be in the back also,bad strut plates and are a very common problem.Which Engine,the 3400 or the 3800?
auto trainy
11-01-2009, 06:31 PM
A friend of mine had a noise similar to what you describe and the noise turned out to be the starter drive being worn and hitting the flywheel when slowing down,just a thought.
risefedup
11-03-2009, 05:44 PM
The engine is a 3800. I have now been told that I have two motor mount bolds broken off and need replaced. Could this cause the problem. I can actually feel a loseness in the brake pedal. I am at wits end with this car. Thanks for your input.
gordon_gjs
11-05-2009, 02:06 PM
I am having a similar problem on my 03 3.8 impala ls. When I turn at low speeds I hear a crunching noisy come from the front end. I plan on looking in to it in the next few days. But you say you're noise is only when you are slowing down or stopping?
risefedup
11-06-2009, 10:34 AM
When I turn my wheels at a slow rate especially, I have a rubbing noise. when I brake I have the crunching nosie. I do think some of my problem is the motor mounts. But, there is definately an issue with my braking system.
gordon_gjs
11-06-2009, 11:55 AM
mine is only when turning (not braking). If I find out that the noise is on my car I will let you know. Maybe it might help you solve you're problem.
