2000 Buick interior door panel
shirley6don
10-29-2009, 10:47 PM
I have a window on drivers side that is down and will not go up. I am trying to take the door apart so I may replace broken part. I have been unable to get interior door panel off, have loose on right side near hinge side, however can not figure out where the clip is the loosen left side of panel. Thanks for any help.
rustbucket
10-30-2009, 06:21 PM
I did a '99- it may be the same. There was a bolt inside of the red reflector on the edge of the door. (Also a bolt underneath the switch panel, you may have found)
polarzak
10-31-2009, 07:36 AM
This site should help you.
www.Bodyshopzone.com
Scroll down to the bottom and pick your vehicle.
stuzman
11-01-2009, 06:54 PM
This link will help you...check post #6
http://www.automotiveforums.com/vbulletin/showthread.php?t=454436&highlight=driver+panel
