93' Camry, no gas and no sparks
antoniyen
10-26-2009, 10:46 AM
Can anyone please help me on this one,
I have a 93' camry and after putting gas and try to start again, the car didn't start.
I check the fuel pump and replaced beacuase I thought it was, but after checking everything
fuses Ok,
No spark
No gas (I put direct current using a wire from the battery positive to the wire positive to the pump and the pump starts, so that means that I have no current to the wires of the pump and no spark too)
I wonder if there is any main relay/fuse that controls both the gas pump ignition and distributor sparks
somebody please help me on this.
:runaround:
RIP
10-26-2009, 05:24 PM
Which engine? Have you checked for OBD fault codes? Procedure is in the Factory Service Manual thread at the top of the forum.
I would suspect you lost the RPM signal to the ECU. This will cut off spark and in-turn via the ECU and circuit opening relay, power to the fuel pump. It's a fail safe mode designed to prevent engine damage and excessive emissions.
antoniyen
10-27-2009, 04:09 PM
It is a 4 cilinders, I haven't checked the fault codes, this car has passed though a lot of damage, it doesn't have sterero, with a lot of cables in it.
how can I fix the RPM signal or/and circuit open relay?
RIP
10-28-2009, 02:37 AM
First you have to check for error codes to verify which direction to go.
