99 Tauras SE Power Steeringjakeyf08 10-25-2009, 08:45 PM I have a 99 Taurus. The Power steering is making a humming noise. When you steer it gets very loud. The fluid level is a little low. It was fine when it was checked just a week ago. I believe the pump is bad? If this sounds like the case does anyone have some help make the change easier? Any help would be appreciated. jakeyf08 11-07-2009, 06:16 PM I changed the power steering pump on a 99 taurus about 2 weeks ago. It ran fine, the steering was alot smoother than before, and the noise was eliminated. I checked the fluid level daily and added some if needed. Then one night the power steering just went out. It was completely gone. So the next morning I checked to see where all the fluid went. The clamp on the boot on the passenger side of the steering rack was off. Do I need to replace the entire steering rack to fix the issue? or can i put the clamp on and get it to hold fluid again. Also what could be the cause? air in the system? any help would be greatly appreciated. Airjer_ 11-07-2009, 09:20 PM The boot is just a protective cover to keep out dirt/water. If there was fluid coming out of the rack, the whole rack will need to be replaced. mwt47 11-08-2009, 11:24 AM You eventually will need to change the pump. In the mean time I have used one of the Lucas products to make it quiet down. jakeyf08 11-08-2009, 02:49 PM Is the steering rack going to be a difficult swap? Im at school right now so I dont have tons of tools with me or time to do it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
