new to these trans sports, relay questionallen405 10-16-2009, 07:39 PM I recently purchased a 1995 trans sport, and I guess it is ok for the most part. I discovered they are mostly plastic, but that is neither here nor there. The left window doesn't work very well you have to work with it for a long time to get it to go up. It will go down no problem but going up is a major pain in the rear. would anybody have a clue why it does that? LMP 10-16-2009, 09:51 PM Mine is working slowly too to get that left window up but not dramatically. ANyway, I'm sure I would someday peel off the door panel and lubricate the window rails and mechanism. That should work it out. allen405 10-17-2009, 01:08 AM I will give it a go Jrs3800 10-17-2009, 04:43 PM Either that or the window motor is getting tired.. I have one fail after the other one... Both windows are pretty quick when everything works as it should.. I have a 95 TS as well.. Does yours have the Power sliding door and keyless entry? allen405 10-17-2009, 11:56 PM no it doesn't have keyless entry or power slide door sounds nice tho'. Today however I replaced the front valve cover gasket on the engine, I got the back one to look forward to next week that one is gonna suck but oh well. I changed the alternator on friday that wasn't to bad. Airjer_ 10-18-2009, 12:11 AM Get a can of silicone spray and spray the tracks with it. No need to remove the door panels. Roll down the window, spray the tracks roll up the window repeat as necessary. Other uses for silicone spray? In the great northland you can spray it on a cloth and wipe down all the door seal. Keeps the doors from freezing to the seals when you go through the car wash in the winter! jarl 10-18-2009, 01:14 AM no it doesn't have keyless entry... Are you sure? Check the sticker with the options inside the glovebox. Is option AU0 listed? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
