1994 Toyo Camry LE 6 cyc. Check engine light HELP
Salcines1
09-29-2009, 02:33 PM
So I've had this car for over 2 years since we've moved to GA I need to pass Emissions. The check engine light is one and would you believe I haven't been able to find an OBD I reader for this problem. Does anyone know how to pull the codes manually? Also, could the reader just need an adapter? We have an autoxray reader? Can not find a specific Toyota plug though? I need help asap because tomorrow is the last day of the month and i need to register this vehicle which is our only vehicle!
Airjer_
09-29-2009, 03:17 PM
http://i83.photobucket.com/albums/j293/airjer/AF%20Stuff/camry.jpg
Airjer_
09-29-2009, 03:18 PM
Datalink connector is in the engine compartment near the passenger strut tower I believe.
jdmccright
09-29-2009, 03:33 PM
I may be wrong but I think that Gen III Camrys wuth the V6 are already OBD-II compliant. Any parts store can read it for you for free.
If not, there is a Data Link connector under the dash behind the change holder where two terminals are shorted to cause the "check engine" light to flash the codes in sequence. I can't find the exact terminals now, so let me know if you need them. DO NOT TRY THIS FOR OBD-II EQUIPPED CARS and don't start sticking shunts into the connector hoping for the best.
Hope this helps!
[EDIT] Airjer posted as I was writing this...never mind.
Airjer_
09-29-2009, 03:59 PM
otherwise the one I'm thinking of is this one?
http://i83.photobucket.com/albums/j293/airjer/camry.jpg
GSS123
09-29-2009, 05:46 PM
yours should be OBD-II with the V-6 engine.
Brian R.
09-29-2009, 07:55 PM
There is also an OBDII connector under the dash, next to the steering column. You need a code reader.
