1995 neon p0734charlie40 09-26-2009, 06:02 PM can any help with this code. is it in the tranny or on the outside? thanks. charlie40 09-26-2009, 06:11 PM sorry code is 743. tc electric . das2123 09-27-2009, 12:30 PM Are you sure that's the code? charlie40 09-27-2009, 01:17 PM yes i checked it again and that was it t-converter electric . das2123 09-28-2009, 07:58 AM I haven't heard of that code for a neon. The 95 neon isn't fully OB2 compliant, so maybe try the key dance to see what code it throws. What is the car doing? mopar_rocks 09-28-2009, 12:17 PM Hi all .... my first post here!! Great Forum!! That code (PO743) would refer to a Torque Converter Clutch Solenoid problem and is typically found in the Neon. It's possible the converter may not be locking up and will not drop RPM's when it should or it will cause the car to shift improperly as in at the wrong RPM's. Hopefully this is of some help. das2123 09-28-2009, 12:18 PM Ahhh, I didn't look at the 2nd post where the code was different. Good eye mopar_rocks! charlie40 09-28-2009, 04:01 PM thanks for info has any one changed this seloniod before can it be done at home or should i take to a dearlership? mopar_rocks 09-28-2009, 05:44 PM thanks for info has any one changed this seloniod before can it be done at home or should i take to a dearlership? If memory serves me right, the switch is located above the valve body of the transmission, so if you're not comfortable removing the trans pan, the filter and then the valve body, you may wanna consider a garage you trust to do it. The part (again going on memory) was in the $30-$40 range. It's not hard to replace, but will require some time and patience if you've never done one before. There is an electrical connection on the front of the trans. Check the connector and clean it. :) A good repair manual will help alot if you want to try to tackle it .... if not .... dealer or reputable garage it is. Good luck! charlie40 09-28-2009, 07:55 PM Thanks alot im going to try this myself this weekend. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
