1997 Dodge Avenger with front end vibrationThundr5 09-26-2009, 05:54 PM 1997 Dodge Avenger 6 cyl Front Automatic 66,000 miles Hello there. I have a 1997 Dodge Avenger that I just recently put new tires on. They are 215/50/17 Uniroyal Tigerpaws, which replaced the Michelin Pilots that had been on the vehicle. Since then, I've had a vibration problem. The wheels have been balanced twice, the alignment done twice as I had to replace the front stuts. My mechanic also went through the front end to check if anything was needed, as I know these cars had a recall on them for balljoints and control arms. He says everything looks good. Still......it vibrates. It was never like that prior to the tire change. I plan on checking the balance once more, as I'm suspecting a tire issue at this point. What would your opinions be?? Thankyou. Jim 91 bird 09-26-2009, 10:43 PM i once got new tires on some extra rims. they had a vibration after balance. then got them balanced again, the shop person took me to the machine a pointed out that the rims were out of round. that could be a problem worth looking into. did they get damaged during the tire swap? Thundr5 09-29-2009, 06:31 PM Turns out the front left wheel is bent. I don't know if they did it during the tire swap, but I do know the car was fine prior to that. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
