Hesitation from StopFRANKENCAMRY 09-19-2009, 05:40 PM I have a ’94 (LE, 3FSE, auto trans, 220K miles) with a hesitation problem. When starting up from a full stop (stop light, stop sign, etc…) there is are few seconds of hesitation/loss of power as RPMs build from idle. It never lasts more than a few seconds and only happens when I’m just starting to move from a stop. Seems to be worse if the car has been sitting in the sun. Six months ago I removed and cleaned the IAC valve and replaced the EGR valve. Anyone know what this might be? RIP 09-20-2009, 03:59 AM Simple stuff first. Old plugs, plug gap too wide? Solid plug to wire/coil contact? Dirty injectors, weak fuel pressure? When was last tune up? A little deeper. Weak coil, TPS output erratic, weak fuel pump. Other than tip-in problems any rough running, missfire problems? No check engine light right? Mike Gerber 09-20-2009, 11:03 AM First of all if you have a 94 Camry the engine is the 5SFE. To add to what RIP recommended, misses under load are most often caused by faulty ignition system components. I would threfore also add checking/replacing the spark plug wires. How old are the plug wires? When was the last time they were replaced? Were they replaced with OEM or aftermarket wires? Mike FRANKENCAMRY 09-20-2009, 11:35 AM Thank you both. Pardon the engine type-o, its the 4 cyl. Check eng light is off. Ignition wires are OEM but pretty old. I'm going to replace wires and plugs as first step. Will post results. Mike Gerber 09-20-2009, 02:38 PM "I'm going to replace wires and plugs as first step. Will post results." I would avoid the cheap aftermarket wires and stick with OEM. In my experience the cheap aftermarket ones need to be replaced again in about 1 year or 20,000 miles. Try some of the online Toyota dealer websites for a good price on the OEM ones. Mike RIP 09-20-2009, 04:45 PM "I'm going to replace wires and plugs as first step. Will post results." I would avoid the cheap aftermarket wires and stick with OEM. In my experience the cheap aftermarket ones need to be replaced again in about 1 year or 20,000 miles. Try some of the online Toyota dealer websites for a good price on the OEM ones. Mike Ditto. Went through two sets from AutoZone a few years ago. Got the first set only because I needed them fast and they were close. One failed a year later. Replaced under warranty. Second set failed 8 months later. Replaced with OEM almost two years ago and no problems since. FRANKENCAMRY 10-17-2009, 09:00 AM Following up... wires, plugs, cap, and rotor all seemed to be original parts (wires had the year on them - guessing on the rest). Replaced all with OEM/NGK and it's running better than it has in years! RIP 10-17-2009, 05:15 PM :thumbsup::cheers: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
