'98 Regal LS Security Light Onheyraver 09-14-2009, 01:16 AM '98 Regal LS... When starting up my car, my security light will sometimes stay on. The car drives fine, doesn't stall, fires right up, no problems. When I turn the car off and start it back up, the light turns off. Sometimes i'm able to pull out the key in the ignition unlock position... It's not a big issue to me, but i'd like to fix it before it becomes worst. Any ideas?? Thanks BNaylor 09-14-2009, 08:17 PM Have you tried cleaning the resistor pellet on the Passkey II key or tried a spare key? Also, try a relearn. Key in ignition ON for 10 minutes and off for up to 30 minutes. heyraver 09-14-2009, 11:58 PM No, never thought of cleaning the resistor pellet. Is there any special way of cleaning it? And I lost the spare key a while back, so that idea is a no go... After this issue started, my keyfob stopped working. I've changed the battery plenty of times and tried the remote synchronization, but to no avail. I'll try that relearn method you told me and let you know how it goes. Thanks for the tips vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
