Same size tires F & R on a 350Z
glovez
09-07-2009, 12:14 PM
Hello Everyone
Anyone know is you can run the same size tires on the front and rear? like 225/45R-18 all around or maybe step it up a size to 235/45R-18 all around. If anyone did this how was the performance? I want to go to same size tires so I can rotate the to get even wear and a little longer life from the tires. This will be on a 2006 350Z.
Thanks for your help
Dave Z
rmhockman
09-10-2009, 10:30 AM
Beats me, but that is a valid question as non rotating puts you at risk for faster tire wear, how about using touring tires with much higher tread wear ratings rather than high performance? I don't know how 235's all around will fit the front end properly without rubbing! Keep me posted!
