Press Gas / Little movementthepriz 09-04-2009, 04:29 PM I have a 2002 Venture. I have an intermittent problem. When stepping on the gas the car does not go very fast, and the engine does not rev up. I replaced the gas filter, but it still is doing the same thing. My next guess is the gas pump. Am I looking in the right place? Is there anything else I should look at? Thanks, Dennis Przybyla roadrunner2 09-04-2009, 11:23 PM I have a 2002 Venture. I have an intermittent problem. When stepping on the gas the car does not go very fast, and the engine does not rev up. I replaced the gas filter, but it still is doing the same thing. My next guess is the gas pump. Am I looking in the right place? Is there anything else I should look at? Thanks, Dennis Przybyla Don't replace anything else until you have a fuel pressure test performed as you might be 'throwing parts' at the problem. You need a proper diagnosis first. Fuel pressure tests, one with engine off/key on and one with the engine idling. manicmechanix 09-13-2009, 03:32 PM Also you might have a plugged cat. A lot of GM vehicles around 2002 had problems with the cat plugging up and restricting the exhaust. The engine would have no power and would not rev. AdVenture 09-20-2009, 06:35 PM What codes are you getting? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
