1994 O/D won't stay engagedtrp52us 09-04-2009, 03:41 PM Just replaced the engine in my 1994 Villager and now the O/D won't stay engaged. When you turn off the O/D it runs smoothly. We are planning a 6 hr trip in a week and don't want to run it that long without O/D. All help is appreciated. Keystone742 09-04-2009, 04:50 PM I’m not sure about a 1994 Mercury, but I had the same problem with a Buick once after I replaced the tranny. There was a connector that I missed, it was for the electronic lock-up for the torque converter and was necessary for it to stay in O/D. Once I reconnected it, it worked fine. Hope this helps. trp52us 09-05-2009, 01:34 PM Thanks for the advice. Rechecked all connections and still not working. Reset the timing and it helped some but still won't stay engaged for longer than 10-15 seconds. As long as you are accelerating it stays engaged but when you hold the speed or slow down it kicks off. When we changed the CV joints there was a lot of trans fluid that leaked out but the dipstick still reads full. I added more just in case but still no change. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
