1990 lesabre ses problem
hendrix016
09-01-2009, 02:16 PM
when you first start the car it runs real rough, so i have to let it idle for a min or it will stall out. but once i let it idle it is fine to drive until i drive it for about 45 min straight then the temp light comes on. i just turn the heat on and it goes off. but what could cause this. i changed the tps but it still runs the same. any suggestions.. thanks
HotZ28
09-01-2009, 02:43 PM
Low coolant level, stuck theromstat, coolant temp sensor & idle air control are just a few suggestions.
auto trainy
09-04-2009, 07:43 PM
Have you been putting in coolant lately?
hendrix016
09-13-2009, 10:38 PM
yep coolant is fine. the light came on a few weeks ago when i gave it heavy gas to pass somebody.
HotZ28
09-13-2009, 10:50 PM
Where did you check the coolant level, at the reservoir or the radiator? You may have air in the system. Basic diagnostics required here.
hendrix016
09-14-2009, 11:53 PM
i add directly to the radiator when i add coolant
