97 camaro choking everyone!dapopes 09-01-2009, 04:50 AM got a 97 3.8 camaro that runs so rich, that it chokes anyone behind, in, or even close by due to exhaust fumes!! Also runs rough, and gets CRAPPY milage. The diagnostic plug doesn't work, so can't go according to the codes. Does this sound like an o2 sensor or dirty egr valve? How many 02 sensors on this car? Thanks for any help! jason-1995fbody 09-01-2009, 08:44 PM need to figure out the aldl connection problem this might be part of the issue dapopes 09-04-2009, 04:49 AM Yeah, I,ve looked to c if I could find why aldl won't work. I guess I'll have to pay someone to find problem. Oh well!! That's better than spending a wad, and still not solve the prob! I'll let all know what it was! dapopes 09-07-2009, 01:58 PM Well, I got a code finally! said I needed a crank pos sensor. After install, it still runs rich, and rough. No more codes, but still runs like garbage. Any ideas? firing order is correct, etc.:banghead: Genopsyde 09-08-2009, 05:40 AM A faulty coolant temp sensor for the ecm can cause this problem. it's a cheap part and worth a shot. it won't trigger a code either. dapopes 09-08-2009, 04:07 PM It turned out to be the coil for number 6 plug. $23.00 fix. Well, $50.00 with the cps too. Runs great now, and light went out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
