95 Transport 3800 NO HEAT- how to flush system?
500hpgtx
08-22-2009, 09:35 AM
Well well- back again to this problem. Heater core was the culprit
last time - replaced 2 years ago.
This modle van has the dual heater core setup.
Should i do a system clean with a prestone coolant system cleaner?
HOw should I go about removing the very possible obstruction? Reverse
flushing the system, and where would I tyr to force water through?
Would you suggest using a T-in line kit for back flushing, or would the valves for the rear heater core obstruct back flushing?
I HAVE to get this right before cold weather...my son has a tought problem
with Rheumatoid Arthritis, and he is very susceptible to cold drafts...
Your guys experience with this modle is GREATLY apppreciated....KEV
500hpgtx
09-01-2009, 03:29 PM
Bought prestone system cleaner with main ingredient of sodium citrate(mild alkaline). Drained radiator and added sytme cleaner. Drove vehicle for at least an hour-cold heater core. Added 2nd prestone cleaner and drove for a total
of about 6-7 more hours of several days. Heat fully returned. Flushed system with opne petcock continually running vehicle. Drained and added almost 2 gallons of anti-freeze.
This vehicle probably had never had a systme clean like this. Sodium citrate is a very mild alkaline solution, and probably neutralized acid buildup from the old anti-freeze and crud buildup in the system....working very well, but 70 farenheit outside......KEV
500hpgtx
09-07-2009, 09:03 AM
My intuition was working overtime when I did the long system clean, and
after the heat seemed to be working strong, the water pump started to leak. 117K miles not too bad for a water pump. A solid 3+ hours to install
it; factory water pump gasket real fun to remove with a razor blade.
Escoffier
09-24-2009, 06:59 PM
I'm replacing a water pump on my 95 3800 now, Good info on the flush I wanted to flush mine first but the old WP didn't agree. Did you back-flush? Where did you access the system? I bought a flush kit but havn't opened it.....I need more info first.
500hpgtx
09-25-2009, 08:27 AM
I did not back flush the system. I do not like the possibility of plugging the system with the dual heater cores. Again, I used the Prestone system clean, which is a mild alkalizing
agent, and eneded up using 2 larger containers. The key is to drive the vehilce for several hours. I ws concerned about loss of lubrication for the water pump, and alas, I ended up rreplacing it. At 120K miles, due for one anyway. Better now than in early February (near Chicago).........good luck....I hope my heat works when it is cold...KEV
