91 Dodge Dakota - No Sparkrjk444 08-05-2009, 08:58 PM 1991 Dodge Dakota 3.9L, 6 cylinder, turns over easily, won't start. No spark at plugs or end of coil. Changed coil and distributor. When trying to start volt meter shows about 10 volts at positive and negative terminals of coil. Fuses and relays SEEM okay. Swapped them around and no difference. Check engine light, oil symbol light, ABS all come on, so engine controller is active. I am out of ideas. HELP! din365 08-09-2009, 03:59 AM did you check your distributer cap and made sure it wasn't loose? how old are the spark plug wires on it? skycor 11-16-2009, 06:57 AM read my post RE:no spark/fuel FIXED on previous page. might help, although i did not have a check engine at the time of the problem and did after i fixed it. still... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
