03 Rear Power Windows not workingttherman 07-21-2009, 11:03 PM Both rear power windows on my 03 EXT stopped working at the same time; driver's console will not operate them either. Front windows work fine. All Fuses check good. Any ideas? maxwedge 07-22-2009, 01:14 PM Master switch one issue, window control module another, get it checked out to avoid expensive parts changing. ttherman 08-04-2009, 08:21 PM I pulled off the Master switch (GM part# 15180052) I do not have a wiring diagram, but I measured the voltage at the various orange wires. All measure 12.4V except no reading (0V) on the thin orange wire on the middle connector. Would this indicate a bad switch? Is a wiring diagram available? maxwedge 08-05-2009, 09:11 AM Yes go to autozone.com, repair guides. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
