98 Voyager coolant leaksprucebingsteen 07-20-2009, 11:53 AM hello, I have a 98 grand voyager 3.3l and 240,000 kms on it. I ahve a small pinhole leak at the top of the rad beside the cap. I guess it is the top of the plastic tank. any way of covering up this hole since its plastic and flat. thanks RIP 07-20-2009, 01:25 PM You could try using a high heat epoxy filler but, that's a temp fix at best. I'd bet your hole is a tiny crack. It's only going to get worse. sprucebingsteen 07-20-2009, 02:08 PM very tiny cant even see it when cools down. prob from high heat plastic expands. anyway put a very thin bead of silicone on it. hope it cuires well and solves prob temporarily. ricebike 07-20-2009, 02:17 PM silicone won't do it, even for a temp fix... gotta use epoxy/resin as the other poster noted... since the system has to be pressurized via rad cap or cooling efficiency goes to shiat... do it while the vehicle is cold/ parked overnight... spray brake cleaner on affected spot, sand if u wish, and respray and let dry... mix the epoxy together and paste it on, wait to cure... then should be good to go! sprucebingsteen 07-20-2009, 02:34 PM ok thanks will try tomorrow if as you say the silicone dont work.... 2 part high heat epoxy Automotive Network, Inc., Copyright ©2012
