1995 bonny starts than quitsbrock053187 07-11-2009, 03:42 PM my bonneville one day started up and than quit all of a sudden and my windows stopped working.....tried 10 times or so and wouldnt work or start...than at nite time it started up....the next day i drove it all day and windows workd fine.....than the car died 11pm that nite.....been doin this every since....new plugs wires fuel filter....u can hear the pump kinda...thinking either change the pump or the mass air sensor or crank sensor but y would the windows not work either????/ Jrs3800 07-11-2009, 04:19 PM You may need to check the grounds for corrosion, you may also need to check the battery cables positive especially.. If you have not cleaned the batter cables please do so maxwedge 07-11-2009, 08:26 PM Welcome to AF, the symptoms piont to a bad ground junction in the harness under the l/f door side sill plate, accessed by folding back the carpet, this affects the windows and fuel pump, quite common. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
