Want to make your 3L LeBaron a stick shift?
madmanmapper
06-20-2009, 03:06 AM
Then I've got what you need! I have an A543 5 speed manual transmission from a 93 Plymouth Sundance Duster with the 3.0L engine and I have all the cables, mounts, wires, the shifter, and the brake/clutch pedal assembly. The only things I don't have are the interior parts (such as the shifter boot), the car's frame, and the axles (from what I hear, the A604 axles fit it). I'm sure you can chop up your interior to fit the shifter, stitch together a boot from an old leather couch, and weld a piece of sheet metal to your frame to hold the back trans mount. Otherwise I have everything you need for a conversion and I'm looking to sell it! Failing that, I'll put it in my own LeBaron, so act fast before I change my mind! All of it is sitting on a shelf in my transmission shop on the north side of Chicago.
Specs:
A543
5 speed manual transmisson
Final Drive Ratio: 3.77:1
Manufacture Date: 5/4/93
