Our Community is 662,000 Strong. Join Us.
03 dodge grand caravan turn key nothing
isie
05-18-2009, 05:56 PM
I am working on a neighbors 03 dodge grand caravan with a 3.3liter. when you turn the key nothing happens. I read the other post on this subject and did the following.
on the starter relay I jumped #30 to #87 van turned over would not run with key on
voltage to #86 was 12volts when key turned to start
#85 had a ground
tried putting it into nuetral and same thing, when you put it into reverse the reverse lights do come on. does anyone have a suggestion as what to do next. I also shook the harness at the tranny and by the engine to see if there was a short or anything.
thanks
isie
isie
05-19-2009, 09:44 PM
nobody?
tempfixit
05-19-2009, 10:53 PM
Check this thread isie, hopefully it will help you:
http://forum.chryslerminivan.net/showthread.php?t=9915&highlight=ignition+switch
