no power from battery to carb1wiles 05-17-2009, 10:22 PM 1995 avalon. Left key on all night. The battery died, it is only 6 months old held a good charge. Put battery back in and now no power anywhere to car. No lights, at all, pulled plug from back of ignition switch and no power there either. Clean terminals on battery, good ground ..tried to jump start no change. Pulled the big fuse that says main engine and could not read any power on the terminals..please help haovnp2 05-18-2009, 09:56 AM your battery was died, i think so. Maybe it can not be charged. you put it out of your car so long. you need replace it by a new battery. ricebike 05-18-2009, 11:32 AM bring battery in to be load tested by your auto parts place... they usually do it for free... charge it up again & then go in... tell the counterperson to load test it after "being charged up" battery only 6 months old? have receipt ready for a warranty-exchange just in case it failed the load test... b1wiles 05-18-2009, 10:32 PM found the problem, it is a 120 amp fuse labled alternator; that bolts into the main fuse/relay box under the hood. Problem is I can't seem to find one..any ideas would be appreciated... ricebike 05-18-2009, 11:23 PM dealer or salvage yard if your local auto parts store can't get one... GL jdmccright 05-19-2009, 03:23 PM I'd have the alternator tested as well. Otherwise, you could just waste time finding an alt fuse only to blow it again due to a bad alt. Hope this helps! mazahreh 11-23-2009, 03:01 PM how can I program remote key of avalon 2000 to use it on my other car avalon 2000? thanks in advance vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
