Page updated on 04-23-2018
2005 Town & Country Engine Codes
knjwells
04-27-2009, 05:51 AM
2005 Town & Country 6 cyl. Automatic FWD 44,600mi. Engine Codes
I have an engine light on so I cycled the key on and off three times to get the codes P 2097 -and P 0138. Could you tell me what each one of these are implying? Thanks so much for your time.
cbwilsha
04-27-2009, 10:28 AM
P0138 is a faulty Oxygen Sensor. There are two--the Upstream Sensor mounted on the Exhaust Manifold and the Downstream Sensor mounted on the Cat Converter. Unfortunately, P0138 doesn't tell you which one is bad.
I can't find any record of a P2097 code.
C.B.
tempfixit
04-27-2009, 10:56 AM
Here is a link with the code descriptions:
http://www.allpar.com/fix/computer-codes.html
P0138 is a high voltage output on bank 1 sensor 2 (bank 1 is the same side as #1 clyinder, sensor 2 is after convertor) I would check for a rich fuel/air mixture causing the cat to overload.
P2097 is cataylitic convertor related.
Hope this helps
jpb53
04-27-2009, 10:58 AM
P0138HO2S 12 Circuit condition (Heated Oxygen Sensor Bank 1 Sensor 2)
– The powertrain control module uses the oxygen sensor to calculate the air/fuel ratio in the exhaust.
P2097ChryslerDownstream Fuel Trim System 1 Rich or Lean
– The ECM has detected a fault with the downstream O2 sensor
Bank one is the bank with cylinder #1 on it.
RIP
04-27-2009, 02:38 PM
Not much new here. P0138 flags the downstream HO2 sensor. That's aft of the converter as stated. Just a couple of websites for future reference: http://www.obd-codes.com/p0138
http://www.iequus.com/support/obd2_definitions.php
