door lock punched in - 98 Grand Voyagerhodef56 04-07-2009, 09:17 PM I have had my driver side door lock punched in by vandals. How to I go about fixing it? Thanks in advance ricebike 04-08-2009, 12:19 AM remove door panel from the inside to access the door lock/handle assembly you'll need to disengage a metal rod from the lock cylinder to the door handle... autozone has a free repair guide for this vehicle a step by step chiltons/haynes' style w/ some good pix for you... i can't post the pix for you/ just go there http://www.autozone.com/autozone/repairinfo/repairInfoLanding.jsp edit: well i see you already found an online source to do this job http://www.automotiveforums.com/vbulletin/showthread.php?t=890937 hodef56 04-19-2009, 02:24 PM Hi, Thanks for the info. I will give it a try. remove door panel from the inside to access the door lock/handle assembly you'll need to disengage a metal rod from the lock cylinder to the door handle... autozone has a free repair guide for this vehicle a step by step chiltons/haynes' style w/ some good pix for you... i can't post the pix for you/ just go there http://www.autozone.com/autozone/repairinfo/repairInfoLanding.jsp edit: well i see you already found an online source to do this job http://www.automotiveforums.com/vbulletin/showthread.php?t=890937 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
