01 Ford Windstar knocking sound from enginge compartment
johnmaster
04-07-2009, 11:26 AM
2001 ford windstar with 100000 miles has a light knocking sound comming from the right side of the enginge compartment had oil change recently... any advice will be very helpful thank you.
garync1
04-07-2009, 02:01 PM
Ok just curious...If your oil level is good. While at idle grab your top upper intake and push down hard with your hands to see if the knock will go away.. I had to replace the upper intake clam shell because the baffle broke loose from the top. Sounded just like an engine rod knock.. A few years ago it was around a 150.00 bucks.. I am sure it has dropped some since..
schadd1971
04-07-2009, 09:44 PM
Yeah its the upper plentum i had the same problem....about 100 bucks on a1 autoparts web site
mustangmanic73
04-09-2009, 04:39 AM
I took mine apart and glued with rtv sealer and all is well. It wasn't knocking till I did the isolator bolt fix.
jgattian
04-17-2009, 12:07 AM
+1 Glued mine 3 years ago when is did the isolator bolt fix.
