Oil Change and service indicatordjbpmlaw 10-23-2001, 10:51 AM I changed the oil in my 323. How do I reset the service indicator? Ultimateone 10-23-2001, 03:20 PM The light has to be turned off by Bmw, its probably the 15,000 mile service light, you are suppose to take it in for service. bjchacha 10-25-2001, 09:18 PM There's a tool that's sold by many aftermarket catalogs for this purpose (there's usually an ad in the back of Road & Track). If you're interested in doing it without the tool, there's good directions on the unofficial BMW site (www.unofficialbmw.com). Just do a search on "service lights" jag 10-29-2001, 10:31 AM Here is a place that sells the tools. Very easy to deal with. Were prompt and courteous with me. http://www.bimmertoys.com/ Hope that helps out. Btw, don't ever take it to the dealership to get the stupid light turned off. Even if you don't buy the tool you can find someone to do it cheaper than the dealer. Believe it or not people the dealer isn't GOD. :) God is much smarter and alot easier to deal with. bry325i 03-21-2002, 04:16 PM If you want to reset your service indicator, jus tkey the ignition over until the service lights come on in the dash, then take the diagnostic connector cover off and ground pin 7 to the chassis (hold it there for about 5 sec.). When you check the indicators again, should be all green again. ;) sfinnerty 05-31-2002, 07:12 PM I think that was an excellent question. And, eventhough you have a faily expensive car, it does not give the dealer the right to bone you for an $80 oil change when you could either easily either do it yourself or bring it to a trusted sevice center. BMW obviously has put the switch in for that reason. forum15 06-19-2002, 08:36 PM Here's a link to a place that sells the reset tools for cheap. http://www.peakeresearch.com/index.shtml neeyew 07-15-2002, 05:10 AM The service light reset tool sold by peakeresearch.com and bimmertoys can only be used for BMW until 1999. Are there any other cheap tools for new BMWs? luvjazz60 07-18-2002, 10:37 AM There is a web page at http://www.unofficialbmw.com/repair_faqs/sil.html that gives you step by step and a picture of the pins so you don't pick the wrong one. Just used it and it worked GREAT! :sun: neeyew 10-07-2002, 03:36 AM The unofficial website has not been updated for a long time. There are no new updates after 1999. The picking of pin 7 is meant for BMW's before 1999. I believe it'll be different for 2002 BMW 318i valvetronic engine. That is why the service light reset tools by peakeresearch.com and bimmertoys can only reset for cars until 1999.. Rossco 10-07-2002, 06:31 AM BMP Design sell a couple of service reset tools for BMW's up to year 2001. Their web site is www.bmpdesign.com (http://www.bmpdesign.com) Priced at $79.95 US each Also have a look at this page, you might find it interesting. http://www.eskimo.com/~dalus/bmw/e36/electrical/e36_reset_service_lights.htm Hope this helps Rossco 1996 E36 320i http://www.automotiveforums.com/vbulletin/attachment.php?s=&postid=518748 BabyBeemer 10-10-2002, 11:13 PM Grounding to the chassis is also equivalent to pin 19 in the data link connector. So, all you need to do is turn the ignition to Acc, use a paperclip to short pins 7 and 19 for 5 seconds, remove the paperclip, and turn off the ignition. Turn on the ignition again and you will see all green bars ;) Bijan 02-09-2003, 03:25 AM Check out this website http://www.bmwtips.com/tipsntricks/reset-plug/reset.htm It explains how to reset the lights on 1999 and on E39, probably it's the same on the 1999 and newer E46. But use at your own risk I haven't used it yet. C_Dogg 02-16-2003, 10:53 PM OK guys, what do I use on a 2001? My warranty will run out soon!:confused: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
