1990 toyota 4runner vibration damper boltRSMMAN1 03-30-2009, 04:24 PM Hello does anyone out there know about removing a vibration damper bolt ,I have tryed to un screw it counter clock wise with lots of force and it will not move ,I hope I am turning it the correct way the repair book says nothing about the direction ,Has anyone done this before ?. Thanks for your help And P.S. I do have the damper locked in so it will not turn just the bolt will not turn Thanks :crying::confused::banghead: Brian R. 04-05-2009, 12:21 AM You are turning in the right direction. Turn harder. Alternatively, put a breaker bar on the bolt, with the handle touching the floor on the driver side of the engine. Brace it on a piece of lumber if you want. Pull ignition wires so that the engine won't start and blip the starter. The starter will loosen the bolt. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
