95 gmc jimmy stuck in second gear.....csmith89 03-25-2009, 11:43 PM I changed the transmission fluid and filter, now it is stuck in second gear. It is fine in reverse.... Any ideas on what I might have screwed up??? No check engine light either... maxwedge 03-26-2009, 12:22 PM Make sure you did not loosen the main plug into the trans , if ok, pull the pan and check the solenoid connections. csmith89 03-31-2009, 12:06 PM shift solenoid...... thank god!!! :smile: Automotive Network, Inc., Copyright ©2013
