Any Microballon tips?
rollover
03-16-2009, 08:48 PM
I bought a bottle of microballons to use for texturing seats, dashes, etc. I did a search but could not find any how to or what to do. Can you give me some tips?
Airbrush or brush
before or after paint
mixing ratio with paint
airbrush pressure and tip size
Thanks, Jeff
Airbrush or brush
Thanks, Jeff
gtziaf
03-18-2009, 06:40 AM
I have the same question 's. :confused:
Can anyone help.. please... :licka: :shakehead
Bartak
03-18-2009, 07:30 AM
I`m doing it according the instructions from hiroboy store. You can find it if you click on the microballoons filler in there. Its simple, spray surface with the colour of your choise, than apply microballons, just from the bottle, or another way (you can use small sieve), doesn`t matter really i think...then i push it gently with my finger, but only slightly (you can skip this if you are not ok with that)...then when it comes dry, apply another coat of the same colour you already used previously because balloons are white. If you are not satisfied with the result (maybe some blank spots) you can simply repeat the whole process again and again and....
