94 Park Ave
ParkAveMan
03-02-2009, 05:40 PM
i have an issue with my AC/HEAT. When I got in the car this morning, i turned my heat on to warm the old girl up and no air blew. AT ALL.... no matter what temperature, no matter how high I turned it, nothing happened. can someone, anyone point me in the right direction on this issue? I am looking for the fuse to the blower motor, to see if possibly that is the issue.
brcidd
03-02-2009, 06:21 PM
With ignition on, tap on the blower motor housing with a blunt object- if it starts, then you have a worn out blower motor-- most likely scenario..
imidazol97
03-03-2009, 06:36 AM
If tapping on the motor starts it you likely have found your problem.
If it doesn't, you may have a blower motor control module that's bad. This is the speed control if you have the automatic tempterature control. If you have a manual lever on the dash to change blower speed you have resistors instead and your fan would have turned on when you switched to highest speed because it's a different circuit.
The blower control module is close to the blower motor but between the blower housing and the relay center on the firewall. The relay center unbolts with 2 screws and can be moved slightly to get room to remove the blower control module.
http://i86.photobucket.com/albums/k110/imidazol97/10-03-07015.jpg
