63 Nova with a Ford 9"
jyatesmp
02-11-2009, 03:37 PM
This is the set up (I bought it like this):
63 Chevy II Nova SS, 327 (replaced the I6), 350 turbo, Ford 9" with 3.73 posi. mono leaf springs, extended shackles, traction bars, sub frame connectors.
I want to swap out the 327 and put in a 388 stroker, replace the auto 350 and go with a 4 or 5 speed standard (no clutch in car as of now) and replace the mono springs with multi leaf, at the same time I would like to put the springs on top of the axle (not on the bottom as they are now).
I would like to replace the parts as I need them and as of now the 327 and tranny are strong, but my axle has lots of wheel hop and I get almost no traction. My stock front drum brakes must go.
Any ideas on how I go about getting my goals met? 1-Replace mono leaf with multi leaf springs, swap from spring under to spring over axle. 2-Go from auto setup tranny to standard tranny (adding clutch in car). 3-Swap 327 for 388 stroker (this one is easy and I think I can take care of it on my own). 4-Swap front 4 bolt drum brakes to 5 bolt disk.
If you have any web sites I can get parts at or intrechangable part ideas let me know.
osylith
02-12-2009, 04:45 PM
www.classicindustries.com (http://www.automotiveforums.com/vbulletin/www.classicindustries.com)
oldblu65
02-13-2009, 12:08 PM
Why do you want to put the springs on top of the axle ? To raise the vehicle ?
jyatesmp
02-13-2009, 08:12 PM
The idea was to help lift thee rear. I think itwill be more trouble than it is worth to do a leaf over swap. I have found some multi leaf 4" lift springs that I am going to go with.
I got the leaf over sawp idea from the truck off road world. To do this I would need to do a lot of cutting and welding, so I will just leave my axles as they are and just swap out the leaf springs.
