trying to find away around the speed limitershinta 01-28-2009, 08:49 PM well the title says it all, but i dont wont to go out and dump 100+ just to get the speed limiter removed. i know with a skyline its the speed senser wire, wonted to know if any one has tried to get around it with buying any thing. MT-2500 01-29-2009, 11:07 AM Why do you want to do that? It is illegal to do them things. shinta 01-29-2009, 02:59 PM the truck is a 4x4 and has never seen a paved road. and i dont fill like paying 1200 for a stand alone ecu, and the piggy back that i have will not take it off that's why MT-2500 01-29-2009, 04:23 PM It is a saftey feature to keep you from going over the speed that you truck is safe to operate. jdmccright 01-30-2009, 12:26 PM No mention of the year and engine/tranny type. Not to prod for details, but I see little value in getting these little trucks to go that fast down unpaved roads unless you're a) racing, or b) an on-site work truck with LOTS of ground to cover. Gotta be hell on the suspension...even with ZR2 pkg. Not that I condone it, but depending on the yr and tranny, could be as simple as adjusting the vehicle speed sensor (VSS). Then it would be illegal to run on roads, but for private property duty (such as a farm), you'd be at your own risk. May I suggest a full racing harness, roll cage, and helmet? Good luck! Blue Bowtie 02-01-2009, 10:06 AM A PCM reflash should solve it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
