More powerTxcoconut 10-22-2001, 12:18 AM I have a 2000 Ext cab Tacoma and was wondering if anyone knows of a power booster available for the 4 cyl(which I have)???:confused: taco_lover 10-26-2001, 01:48 PM There should be a type of bolt on Turbocharger that will work with your truck. The 22RIE engines had them, pretty rare, but if you do some checking you should be able to find one. Check with Kazuma, they do a supercharger setup for the 6 cyl. they may do some type of turbo setup for the 4 cyl, you may even be able to find a supercharger as well. Just do some checking. Also I would suggest a cold air intake with a K & N filter. That's about a 200 dollar mod that would add on. An aftermarket exhaust would boost you up too. Just a couple options for you to check on. Hope that helped you out some. Nate sethmckiness 12-26-2004, 01:10 AM LC Engineering . You can get anything for a 2rz or 3rz there. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
