Car Amp no power but wire has power
dhho1
01-26-2009, 06:30 PM
My car subwoofers stopped working about a month ago. I have that setup for at least 4 years, a sony Amp and 2 10" Infiniti reference subs. About a month ago, the Sony amp power led light didn't light up and of course the subs didn't work. I got a new amp and connect to the power wires and the new amp still won't turn on (led light didn't go on). I checked the power wire and it measured around 11.5 volt. I turned on the car and the remote wire also measured 11.5 volt. But if I connect all the power/ground/remote wires to the amp, the remote wire has 11.5 volt but the power wire will measure 0 volt. I tried 2 different amps and got the same problem. Any idea? Thx.
parrotscaraudio
01-26-2009, 07:32 PM
Have You checked the earth on the body that its not loose
Plus remove ALL pant where the earth conects to the body
Use a BOLT and NUT not a screw
This is common on old installs
If not Give me a call 0430033821 Australia
22 years in car audio instalation
www.rlsnell.20m.com
www.autowreck.com.au
http://z3.invisionfree.com/APV/index.php?
http://www.youtube.com/user/parrotscaraudio:p
www.rlsnell.20m.com
dhho1
01-27-2009, 12:54 PM
[quote=parrotscaraudio]Have You checked the earth on the body that its not loose
www.rlsnell.20m.com (http://www.rlsnell.20m.com)
www.autowreck.com.au (http://www.autowreck.com.au)
http://www.youtube.com/user/parrotscaraudio:p[/quote
pants and earth? I am confused.:screwy:
parrotscaraudio
01-27-2009, 03:46 PM
Plus remove ALL paint where the earth conects to the body
parrotscaraudio
01-27-2009, 03:49 PM
:screwy:pant = paint Typo not that hard to figure out :naughty:
PaulD
01-27-2009, 06:49 PM
earth = common or ground. Where does the black ground wire from the amp(s) go ?
