Speed sensor location on 92 chevy lumina 3.1?
FASTECOTEC
01-18-2009, 09:56 PM
Does anybody know the location of the speed sensor on a 1992 chevy lumina 3.1?
richtazz
01-19-2009, 12:54 PM
The vehicle speed sensor is under the governor cover. In both the 3-speed and 4-speeds, it's just above where the passenger side axle shaft goes into the transaxle.
FASTECOTEC
01-19-2009, 01:12 PM
Do you mean the drivers side? I thought it was on the transmission?
richtazz
01-19-2009, 01:23 PM
No, it's on the passenger side. The transaxle wraps behind the engine. Just follow the CV axle from the passenger side tire to the transaxle and you'll see the plug for the VSS.
FASTECOTEC
01-19-2009, 01:25 PM
Thank you !
FASTECOTEC
01-23-2009, 02:25 AM
I still can not find the speed sensor.Where is it exactly?
richtazz
01-23-2009, 02:09 PM
The VSS on your car is part of the governor cover assembly, so technically it's not a stand alone part. Here's a picture from AC-Delco's website of the governor housing/VSS assembly.
http://198.208.187.182/internet/ViewPartImage.jsp?acdelcoPartNumber=8683968
When mounted on the vehicle, it will be positioned 90 degrees to how it is in the picture. In other words, the o ring will be on the bottom, and the harness plug will be coming out the side. I hope this helps.
FASTECOTEC
01-23-2009, 02:37 PM
I did see that part and thought it was something else.So i have to take that top piece off with the 4 bolts?
FASTECOTEC
01-31-2009, 11:50 AM
It ends up i had the wrong speed sensor that is why i could not find it. thank for the help
