1997 GC - Blinking info panel requires resetting each morningJohng1 01-17-2009, 08:21 PM For the last few months the center console info panel is blinking after starting the vehicle. The time is correct but the date reads January 1 and needs to be reset to the current date. After resetting it all is OK and the blinking is gone. Any ideas ?? Thanks Johng1 07-18-2009, 10:49 PM Bump . . . . .Anyone have any possible cause here? Thanks, 4x4 blazerguy 07-21-2009, 01:33 AM I had trouble with the overhead console info center on our Limited 5.9 I replaced it with a used one from the wrecking yard. I belong to another Jeep forum & it seems these things work or don't. I do know on the ZJ of mine the overhead info center has a processor that does tie into the lower info center. When my upper info center was not working proper I also got a coolant sensor warning everytime I started it up. I replaced the sensor & it still kept coming on & when I replaced the upper unit that cleared up. So I guess I would try & find one in a yard & start there. ozlander 07-25-2009, 06:38 AM For the last few months the center console info panel is blinking after starting the vehicle. The time is correct but the date reads January 1 and needs to be reset to the current date. After resetting it all is OK and the blinking is gone. Any ideas ?? Thanks Dear Jhong, How did you reset the blinking display ? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
