Removing Transmission Pan Bolt 99 PassportSkellies 01-04-2009, 03:56 PM Hi, I'm trying to remove the upper bolt on the tranny fluid pan on my 99 Passport. Its really tight and I'm not sure which way to turn. I drove around to heat up the transmission pan but its still not coming off. Which way do you turn it? Its the one facing up not to the ground. Thanks. Ivan FL 3.2L 01-04-2009, 04:07 PM It is regular thread. counterclockwise if you are underneath looking up at the face of the bolt head. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
