1987 FULL SIZE BLAZER Ignition Problem
MOHAWK02
12-25-2008, 10:23 PM
When I go to start the vehicle, the starter stays engaged, and cranks even after I turn the key to the off position. Any ideas. Also where is the ignition switch located(not the lock cylinder)!!! Thanks
Blue Bowtie
12-25-2008, 10:57 PM
The ignition switch is located on top of the outer jacket of the steering column, near the firewall. It is actuated by a linkage rod from the ignition lock cylinder.
Another possibility is the starter solenoid sticking/contact welding.
79HighSierra
01-22-2009, 07:56 AM
On my 79 I was going through starters like bad hair styles due to shimming issues. When you purchase a new starter if you end up needing one, making sure they come with the new shims could save you a head ache later. If the starter solenoid is not the issue than hopefully this is good info for later :)
