2004 6.0 Hard To Start After Fillup
RAINBARREL56292e
12-21-2008, 09:13 PM
Any Ideas On Why My 2004 Burb With 6.0 Would Require Cranking 10-15 Seconds-then Shut Off Switch-then Crank Again & Then It Will Start? This Only Happens After Filling Up Gas Tank
MT-2500
12-22-2008, 11:03 AM
Check fuel pressure and post back readings.
AutomotiveTech
12-22-2008, 12:03 PM
Are you having cold weather? If so then it is most likely caused by your fuel pump case shrinking when you put all that cold gas in. When the case shrinks (because it is worn) it causes the fuel pump to bind up and not pump as efficiently as it could.
This is just the most likely cause in my opinion
RAINBARREL56292e
12-22-2008, 09:23 PM
thanks guys-does this hot or cold weather- try to get back with pressure readings thanks again
