replaced fuel pump it wont startleones 12-20-2008, 12:10 PM hi, 92 voyager 2.5 engine, running good till it stop on fwy.turn key on no noise coming from pump check juice going to pump there was juice so replace with new unit turn the key on i hear the buzzz noise from the pump but it won't start there is no pressure giong into TB.ps i did not check the fuel filter or take a pressure test dont have the meter any suggestion welcome thanks RIP 12-20-2008, 07:08 PM Not sure on a 92 but on newer vans it's a good idea to prime the pump before installing. Otherwise make sure the tank is near full. leones 12-20-2008, 11:07 PM thanks i'll pour more gas in the thank leones 01-03-2009, 12:45 PM hi sorry i didn't write sooner was away for a few going back to my fuel pressure porblem replaced fuel filter it was ok check battery it's good so i lower the gas tank replaced the fuel pump with another new unit &ta ta engine running so it was a faulty pump that did not have enough pressure to fill the system tanks for your help tempfixit 01-03-2009, 06:10 PM hi sorry i didn't write sooner was away for a few going back to my fuel pressure porblem replaced fuel filter it was ok check battery it's good so i lower the gas tank replaced the fuel pump with another new unit &ta ta engine running so it was a faulty pump that did not have enough pressure to fill the system tanks for your help What brand was the faulty new pump? I had the same problem with a Bosch when I installed it on a 95 Voyager. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
