2000 Voyager won't hold rpms at start and stalls
kev3915
12-19-2008, 01:23 PM
2000 3.3 won't hold rpms after it starts and runs awhile. Start the car let it warm up put in drive give it gas let off the gas rpms crash car stalls. Restart and the car will run fine hold rpms at stops. No codes scaned.
RIP
12-20-2008, 07:19 PM
Could be any number of things. EGR, MAP sensor, O2 sensor... . Sensors can fail without throwing a code. Make sure sensor connections are clean and tight,.
MikeSam
12-22-2008, 12:28 PM
Solid advice, RIP. My 2000 T&C 3.3L had exactly the same problem a month ago (no code). Cleaned EGR, MAP and Idle valve and the problem is gone now. I found a EGR passage metal tube was blocked by the carbon deposit and I took it out with intake cleaner solvent in the process. I spent zero dollars, only cost my couple of hours.
hundahunta
12-22-2008, 11:48 PM
clean the tb and iac
kev3915
01-04-2009, 01:30 PM
Thanks guys... cleaned iav , map sensor, and egr . Problem gone.
RIP
01-04-2009, 07:23 PM
Good news. Thanks for coming back with the fix.
