I Messed Up Bad
mt_100
12-14-2008, 04:59 PM
I went to replace the turn signal switch. Routed the wires for the new one and cut the wires for the old one.
Now I can't get the connector at the block under the dash for the old one undone to hook up the new one.
Think this is going to cost me big money for a mechanic to laugh at me and fix.
Just needed to vent now that I ruined a car in the driveway.
I also accidentally cut the wires for the on steering wheel radio, don't care about that, all other wires in tact.
Scrapper
12-14-2008, 05:18 PM
oboy you really messed up as you said. i really don't know what to tell you sounds like you need someone that knows alot about electric on this one.
good luck.....
mt_100
12-14-2008, 05:28 PM
Actually, Not as bad as I thought. At this point I just have to figure out how to get the connector (long flat and thin) out of the block under the dash. I found out the new switch has a new radio wire set on it (they were taped up).
Once I get that connector undone and the new one in it's place I just have to put it together. Any ideas?
richtazz
12-16-2008, 04:47 PM
There is a bolt in the center of that block. When you loosen the bolt, the block separates, and then the M/F switch harness can be removed.
mt_100
12-17-2008, 08:45 AM
Yep, asked a mechanic and that is what he said. Once I did that and removed the connector, and transferred pins 9 and 10 over all is well. I have turn signals.
