98 Voyager has reverse but no foward gears.winsr 12-13-2008, 05:50 PM My Voyager stopped running on the road no foward or rev. I got it back to my house and aded fluid and now I have rev but no foward gears. It makes a lot of noise when I put it into drive or the lower gears but will not move. I noticed that it seems to make noise in park also. Thanks Win Epistemology 12-13-2008, 07:01 PM Dude, this is going to be expensive. Chrysler's four speed automatic transmissions are notorious for failing (is it four speed/overdrive?). It also shouldn't have been low. However, being low could damage it. Was there a leak? Was the transmission fluid "flushed?" What fluid have you been putting in? You are looking at a transmission rebuild at this point. That will cost you well over a grand. Alternatively, you could go to a junk yard or somewhere else and get a used transmission. You'll need access to some expensive equipment to do a tranny swap yourself. Rawtorque 12-15-2008, 04:33 AM Yep, stick a fork in it; It's done.:uhoh: Noise & loss of gears are a very bad sign. RIP 12-15-2008, 03:27 PM Ya sounds terminal. You can drop the pan and if you see metal debrie it's an automatic rebuild. tbuckit1 12-27-2008, 05:52 PM Chrysler product with transmission failure???????? Tell me it isn't so............. EZFrank 12-27-2008, 09:21 PM mine did the same and the cv shaft broke in half so i replace it and know it is running but sometimes makes a thump noise and like its skipping and stays stuck in first gear. I had mine rebuilt about 4 years ago at contenetal transmission cost me $1800 with new torque converter. Good luck vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
