My "Service Engine Soon" light is on... againHAMcNeil 12-12-2008, 06:28 PM My "Service Engine Soon" light is on again, the the OBD2 sensor gave me the code P0440. I had already had this problem and thought I had fixed it when I replaced the Vapor Canister. Any other thoughts? I was thinking I should replace the Fuel Filter but that is all I can think to do. mike2004tct 12-12-2008, 09:38 PM I had that code when my fuel tank vent hose connection wasn't seated properly, after replacing a fuel pump. Also, Check the vacuum hose to the ball under the hood, and all other vacuum hoses. Any break in a hose along the fuel system line could cause it. Also make sure you have a good functioning gas cap. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
